Talk:ROCK64 Software Releases
Revision as of 19:48, 24 February 2023 by Fxc (talk | contribs) (+sigs +hl +reply)
Order
I'm not sure how this 'Discussion' thing (should) work, but the sequence of the OS images seems rather random and is also not consistent with the 'Rock64' page itself. Should that be fixed? And if so, how? --Diederik (talk) 22:11, 28 April 2022‎ (UTC)
Should be fine now at this point. --Fxc (talk) 19:48, 24 February 2023 (UTC)
Working OS's (almost)
After trying the Manjaro 22.06 versions using various desktops that broke the HDMI output when updates were installed, I had high hopes when I discovered the latest iteration 23.02. Unfortunately it broke the HDMI just like it's predisessor. I made comments on the Manjaro forum about it, to no avail. I didn't write a bug report on Git, I don't know how nor do I have time to learn at this time. This is an example of the "half baked" supported OS's I see people on line refering to.--Flagtrax (talk) 18:21, 24 February 2023‎ (UTC)
Their forums and the wiki discussion page is really the wrong place for this. The correct place is their bug tracker, reporting bugs really isn't hard. In software development, the hourly rate is often in the three digits. I can understand that you don't have time but why do you expect other people to have time and fix your bugs (you don't even report properly) in their free time? This doesn't add up. --Fxc (talk) 19:48, 24 February 2023 (UTC)
