Difference between revisions of "PinePhone Installation Instructions"
m
(→‎Using Growpart: OS agnostic)
Line 106: Line 106:
eMMC: you would need to resize the partition on eMMC (flashed with the operating system) by booting another image from the SD card: that way, the eMMC will be unmounted. It is '''not recommended''' to resize eMMC while booted from eMMC! Resizing a currently mounted partition can have weird results. If you booted from the SD card, you can follow the above guidelines on how to resize from a computer.
SD card: It is generally not possible to boot from eMMC to partition the unmounted SD card, because of the boot order -- you would have to write the image to the empty SD card first, then resize partition, all without rebooting. It is also '''not recommended''' to resize the SD card while booted from SD card! Resizing a currently mounted partition can have weird results.
SD card: It is generally not possible to boot from eMMC to partition the unmounted SD card, because of the boot order - you would have to write the image to the empty SD card first, then resize partition, all without rebooting. It is also '''not recommended''' to resize the SD card while booted from SD card! Resizing a currently mounted partition can have weird results.
== Reuse SD card for data storage on system booting from eMMC==
Moderator
1,491
edits
Navigation menu
