Difference between revisions of "Pinebook Pro Dock"
Switch to "level two"-style for section headings
(add external links)
(Switch to "level two"-style for section headings)
Line 1: Line 1:
Starting point for PineBook Pro Docking station<br>
<br>
<br>
= Description =
== Description ==
The PineBook Pro's docking station was custom designed for both physical dimensions and ports to compliment the PineBook Pro laptop. While it may work for other laptops, convergence devices, (tablets and smart phones), it has not been tested on such.
= Ports available =
== Ports available ==
List of ports available on docking station:
* USB 3.0 Ports x3
* USB 3.0 Ports x3
Line 12: Line 12:
* Card readers: micro SD x 1 & SD x 1, supports: SD, SDHC and SDXC
* Audio Jack: 3.5mm Earphone Jack with mic x1
= Chips used =
== Chips used ==
List of chips used in the docking station:
* PD Negotiation chip - PDFL7102
Line 20: Line 20:
* SD card reader chip - GL823K
* Audio CODEC chip - HZD100
= External Links =
== External Links ==
* [https://pine64.com/product/pinebook-pro-usb-c-docking-deck/ The Pinebook Pro Docking Deck at the Pine64 store]
* [https://forum.pine64.org/forumdisplay.php?fid=116 The "Pinebook Pro Hardware and Accessories" section of the Pine64 forum]
5
edits
Navigation menu
