Difference between revisions of "PinePhone Software Releases"
→‎Factory Test OS: Turn different OS sections into one section and a table
m (→‎PureOS: fix error)
(→‎Factory Test OS: Turn different OS sections into one section and a table)
Line 461: Line 461:
= Factory Test OS =
= Factory Test OS =
On the Braveheart model there was a postmarketOS based basic Factory Test OS pre-installed on the eMMC. The developer Martijn Braam from postmarketOS has improved the functionality of the image considerably later. Since the 20200501 version it is able to test all the hardware. It also includes functionality to install a new OS to the eMMC when using with an test image that includes that OS image. The downloadable image just does the hardware tests. Do not flash eMMC to test your device, just copy it to microSD and test from there. New versions are distributed as part of the postmarketOS distribution.
On the Braveheart model there was a postmarketOS based basic Factory Test OS pre-installed on the eMMC. The developer Martijn Braam from postmarketOS has improved the functionality of the image considerably later. Since the 20200501 version, it is able to test all the hardware. It also includes functionality to install a new OS to the eMMC when using with an test image that includes that OS image. The downloadable image just does the hardware tests. Do not flash eMMC to test your device, just dd it to microSD and test from there. New versions are distributed as part of the postmarketOS distribution.
Links:
Links:
Line 468: Line 468:
[https://gitlab.com/MartijnBraam/factorytest/-/blob/master/README.rst Documentation]
== Factory-loaded postmarketOS build ==
== Factory-loaded OS builds ==
This is a postmarketOS build that was preloaded in the factory with testing utility.
These are different operating system builds that was preloaded in the factory with testing utility.
Download the build, extract the image and dd it to the microSD and then insert it into the phone. Power up the PinePhone, perform and complete the test routine, then apply the build from microSD card to eMMC.
dd the image on a 8 GB micoSD card or larger.
*[https://files.pine64.org/os/PinePhone/PostMarketOS/pine64-pinephone-20200726-phosh-v20.05-factory.img.xz Direct download from pine64.org]
**MD5 (XZip file): 244093be2f6d728fcbd1d29114607727
**File Size: 517MB
== Factory-loaded Ubuntu Touch build ==
This is an Ubuntu Touch build that was preloaded in the factory with testing utility.
*[https://files.pine64.org/os/PinePhone/UBPorts/PinePhone-flasher-ubuntu-7b.img.gz Direct download from pine64.org]
**MD5 (GZip file): 2d7f5271e7a281db8f1b1219bedbe131
**File Size: 1.05GB
== Factory-loaded Manjaro build ==
{| class="wikitable"
This is a Manjaro OS build that was preloaded in the factory with testing utility.
! OS
! Download
! File Size
*[https://files.pine64.org/os/PinePhone/Manjaro/pine64-pinephone-20201013-manjaro-stable-20201018-factory56.img.xz Direct download from pine64.org]
! MD5
**MD5 (XZip file): 4edfd4dceaefdd32a3417c1727161c29
**File Size: 1.04 GB
| postmarketOS
| 517MB
| Ubuntu Touch
| 1.05GB
| Manjaro
| 1.04GB
= Installing other ARM64 distributions =
131
edits
Navigation menu
