360
edits
(→VPU) |
(→VPU) |
Line 61: | Line 61: | ||
In order to allocate more VRAM for the GPU you can add <code>cma=256</code> to your kernel (or use kconfig with CONFIG_CMA_SIZE_MBYTES=256) cmdline in boot.scr which you will have to compile using mkimage. By default the kernel allocates only 64MB, and the maximum value is 256MB. | In order to allocate more VRAM for the GPU you can add <code>cma=256</code> to your kernel (or use kconfig with CONFIG_CMA_SIZE_MBYTES=256) cmdline in boot.scr which you will have to compile using mkimage. By default the kernel allocates only 64MB, and the maximum value is 256MB. | ||
In order to compile boot.scr you can run <code>mkimage -C none -A arm64 -T script -d boot.cmd boot.scr</code> | |||
{{note|You may not have a boot.cmd file in your boot directory and instead you may rather have a boot.txt}} | |||
== Cedrus == | |||
Overclocking cedrus is achieved by modifying the kernel source code: https://elixir.bootlin.com/linux/latest/source/drivers/staging/media/sunxi/cedrus/cedrus.c#L507 | Overclocking cedrus is achieved by modifying the kernel source code: https://elixir.bootlin.com/linux/latest/source/drivers/staging/media/sunxi/cedrus/cedrus.c#L507 |
edits
