Difference between revisions of "Overclocking"
37 bytes removed ,  05:59, 15 February 2021
Line 41: Line 41:
== CPU ==
== CPU ==
Stock speed: 1.152GHz CPU
The stock speed of the A64 is 1.152 GHz. It is not recommended to the overclock the CPU because of the added thermals that it would bring.
Overclocking: TODO
In order to check if the overclock was successfully applied you can run <code>sudo cat /sys/kernel/debug/clk/clk_summary</code>.
== DRAM ==
== DRAM ==
360
edits
Navigation menu
