Difference between revisions of "Overclocking"
10 bytes added ,  05:53, 15 February 2021
Line 45: Line 45:
Overclocking: TODO
Overclocking: TODO
In order to check if the overclock was succesfully applied you can use <code>/sys/kernel/debug/clk/clk_summary</code>.
In order to check if the overclock was successfully applied you can run <code>sudo cat /sys/kernel/debug/clk/clk_summary</code>.
== DRAM ==
== DRAM ==
360
edits
Navigation menu
