360
edits
(→GPU) |
(→GPU) |
Line 25: | Line 25: | ||
== GPU == | == GPU == | ||
Open <code>/boot/dtbs/allwinner/sun50i-a64-pinephone-1.2.dts</code> (You will have to find the source of the kernel used by your distribution. There is the Pine64 kernel, and Megi's) in a text editor following these instructions: | Open <code>/boot/dtbs/allwinner/sun50i-a64-pinephone-1.2.dts</code> (You will have to find the source of the kernel used by your distribution. There is the Pine64 kernel, and Megi's) in a text editor following these instructions: https://wiki.pine64.org/wiki/Overclocking#Edit_Pinephone_DTS | ||
Look for <code>mali: gpu@1c4000 {</code> and within that block search for <code>assigned-clock-rates = <432000000>;</code> | Look for <code>mali: gpu@1c4000 {</code> and within that block search for <code>assigned-clock-rates = <432000000>;</code> |
edits
