Difference between revisions of "Overclocking"
30 bytes removed ,  05:27, 15 February 2021
no edit summary
Line 32: Line 32:
Save the dts file, and recompile the DTB. In order to check if the overclock was successfully applied you can use <code>/sys/kernel/debug/clk/clk_summary</code>.
{{note|The GPU appears to run stable overclocked to 560 Mhz, however more testing with a wider group of devices is needed.}}
{{note|The file may be slightly different and you may need to enter the values as hexidecimals}}
{{note|Remember to run a benchmark tool (such as glmark2-es2) to help check stability.}}
{{hint|The GPU appears to run stable overclocked to 560 Mhz, however more testing with a wider group of devices is needed.}}
{{note|Each device has a slightly different file, you may need to enter the values as hexidecimal such as with the Pinephone}}
{{hint|Remember to run a benchmark tool (such as glmark2-es2) to help check stability.}}
== CPU ==
== CPU ==
360
edits
Navigation menu
