Difference between revisions of "Overclocking"
137 bytes added ,  05:20, 15 February 2021
Line 18: Line 18:
To convert back to DTB:
<code>dtc -I dts -O dtb /boot/dtbs/allwinner/sun50i-a64-pinephone-1.2.dts -o /boot/dtbs/allwinner/sun50i-a64-pinephone-1.2.dtb</code>
Afterwards you can simply reboot and check <code>/sys/kernel/debug/clk/clk_summary</code> to see if the changes have correctly applied.
{{note|In the future it is possible that there will be a driver to adjust clockspeeds of the A64 from userspace without the need to recompile. Currently the only way to overclock is to either compile your own kernel, or modify just the DTB (instructions above).}}
360
edits
Navigation menu
