Difference between revisions of "PinePhone Software Releases"
alphabetical order
(Add distro SkiffOS)
(alphabetical order)
Line 340: Line 340:
OTA is supported: <code>zypper refresh && zypper update</code> as root (<code>devel-su</code> to get root access). Things that need reflash are bootloader specific at the moment. If improvements like crust or changes of partition layout are added then you need to reflash.
== SkiffOS ==
Configuration package manager for [http://buildroot.org Buildroot] cross-compilation tool with support for all Pine64 boards.
Use configuration packages to configure automatic containerized distro setup:
* core/pinephone_neon: KDE Neon via Ubuntu repositories
* core/pinephone_nixos: Nixos Mobile
* core/pinephone_ubports: Ubuntu Ports for PinePhone
You can also configure the skiff core yaml file to configure multiple distros to run in parallel.
The boot-up OS can be upgraded independently from the containers.
'''Download location'''
The repository and instructions can be found [https://github.com/skiffos/SkiffOS/tree/master/configs/pine64/phone here].
== Sxmo ==
== Sxmo ==
Line 360: Line 377:
All the contributing information is [https://git.sr.ht/~mil/sxmo-docs/tree/master/CONTRIBUTING.md here].
== SkiffOS ==
== Ubuntu Touch ==
== Ubuntu Touch ==
Moderator
1,493
edits
Navigation menu
