Difference between revisions of "PinePhone Software Releases"
(We're no longer using lists for that)
Line 307: Line 307:
The SailfishOS image is built on Gitlab CI. The latest image can be installed using the [https://raw.githubusercontent.com/sailfish-on-dontbeevil/flash-it/master/flash-it.sh flashing script].
The script downloads the image and bootloader from our CI, extracts everything and burns it onto the SD card. '''Note:''' The script will format and erase the SD card!
The script downloads the image and bootloader from our CI, extracts everything and burns it onto the SD card. Note: The script will format and erase the SD card!
Instructions:
Instructions:
Line 316: Line 316:
# Execute it: <code>./flash-it.sh</code>
# Follow the instructions. Some commands in the script require root permissions (for example: mounting and flashing the SD card).
'''username/password'''
OR...when asked where to flash, type 'raw' and it will build the image on your pc/mac
Or when asked where to flash, type 'raw' and it will build the image on your pc/mac
OR....download the .img from https://gitlab.com/as400l/pp-sailfishos-images
Or download the .img from https://gitlab.com/as400l/pp-sailfishos-images
Set PIN on initialization.
'''What works, what does not work'''
NB The first run sometimes stalls before the tutorial. Reboot and it starts from setting the security pin.
The homescreen may be locked unless you boot with a sim card inserted. An old expired sim will do. If you do not have a SIM card on hands, do NOT set a security code on first boot. When a screen with a loading circle is displayed, just left/right swipe it away.
Moderator
1,493
edits
Navigation menu
