Difference between revisions of "Pinebook Pro Troubleshooting Guide"
→‎Sound: Redundant heading deleted
(→‎WiFi issues: Added WiFi antenna cable loose fix.)
(→‎Sound: Redundant heading deleted)
Line 80: Line 80:
=Sound=
= Sound issues =
== Sound issues ==
* Many reports of no sound are due to the OS, incorrect settings, or other software problems (eg. PulseAudio). So first test to see if it is a software or hardware problem, by trying another OS via SD card.  (For example, if Debian is installed on the eMMC, try Ubuntu on SD.)
* If you cannot get sound from the headphone jack, but can get sound from the speakers, then the headphone / UART console switch may be set to the UART mode. You can open the back and check the position of the switch. If set to UART mode, switch it to headphone mode. See the parts layout for the location and correct position of the switch.
Line 91: Line 90:
** Their is a software fix using alsamixer and then enable either "R invert" or "L invert", however, now the headphones have incorrect audio.
** The permanent fix is to re-wire one speaker, though this requires soldering small wires.
=Keyboard And Trackpad=
331
edits
Navigation menu
