2,120
edits
Line 14: | Line 14: | ||
* Polished first-run setup which helps you create a user before logging in | * Polished first-run setup which helps you create a user before logging in | ||
* Downloading, installation, etc. details at the [https://github.com/elementary/os/wiki/Pinebook-Pro elementary OS Wiki] | * Downloading, installation, etc. details at the [https://github.com/elementary/os/wiki/Pinebook-Pro elementary OS Wiki] | ||
==Kali Linux== | |||
[[File:Kali.jpeg|right|100px]] | |||
=== Kali Linux prebuilt OS images for Pinebook Pro [SD/eMMC boot]=== | |||
* Official pre-built OS images of Kali Linux for the Pinebook Pro featuring all tools you'd expect from the distribution. | |||
* DD image (for 8GB microSD card /16GB eMMC module and above): | |||
** [https://www.offensive-security.com/kali-linux-arm-images/ Direct download latest images from Offensive Security's website] | |||
** size: 2.0GB | |||
* Login with | |||
** username: | |||
** password: | |||
== Arch Linux == | == Arch Linux == | ||
Line 55: | Line 69: | ||
The [https://gitlab.manjaro.org/manjaro-arm/applications/manjaro-arm-installer manjaro-arm-installer] script is intended to install Manjaro ARM directly to SD/eMMC cards without the need for images (including LXQT, Mate & CuboCore editions, as well as full disk encryption). Running on a Linux x86 computer, it can install Manjaro ARM directly to an empty eMMC using an eMMC to USB adapter. The script can also be run from SD to install an image to the eMMC. | The [https://gitlab.manjaro.org/manjaro-arm/applications/manjaro-arm-installer manjaro-arm-installer] script is intended to install Manjaro ARM directly to SD/eMMC cards without the need for images (including LXQT, Mate & CuboCore editions, as well as full disk encryption). Running on a Linux x86 computer, it can install Manjaro ARM directly to an empty eMMC using an eMMC to USB adapter. The script can also be run from SD to install an image to the eMMC. | ||
