Difference between revisions of "PinePhone APN Settings"
147 bytes removed ,  19:09, 29 November 2020
It's still not relevant for calls or SMS
(It's still not relevant for calls or SMS)
Line 1: Line 1:
The [https://en.wikipedia.org/wiki/Access_Point_Name APN] setting is the gateway between your carrier's cellular network and the public Internet. The APN setting - if not set automatically by the user's OS -  has to be set by the user to enable the use of the mobile Internet on the phone.
The [https://en.wikipedia.org/wiki/Access_Point_Name APN] setting is the gateway between your carrier's cellular network and the '''public Internet'''. The APN setting - if not set automatically by the user's OS -  has to be set by the user to enable the use of the mobile Internet on the phone.
= Setting the APN =
= Setting the APN =
Line 134: Line 134:
== Red Pocket (USA) ==
You can choose AT&T, Verizon, T-Mobile or Sprint network. Known to work with the GSMA (ATT) SIM, calls and SMS work.
APN settings:
APN settings:
Line 176: Line 176:
''BYOP SIM Card Kit'' works with T-Mobile and AT&T compatible SIM cards provided in BYOP kit.
Calls, SMS and 3G/4G data known to work with Verizon & AT&T SIMs (most likely works for T-Mobile as well).
Use the following APN settings:
Line 194: Line 194:
== Verizon Contract (USA) ==
There are several APN names which can be used, but the following has worked fairly reliably for calls, SMS and data on Verizon under arch:
There are several APN names which can be used, for example:
  Name: 4G LTE Contract
Moderator
1,493
edits
Navigation menu
