Moderator
1,471
edits
(Add note about disabling sleep.) |
(https) |
Line 42: | Line 42: | ||
== PineTab board information, schematics and certifications == | == PineTab board information, schematics and certifications == | ||
* PineTab mainboard schematic: | * PineTab mainboard schematic: | ||
** [ | ** [https://files.pine64.org/doc/PineTab/PineTab%20Schematic%20v1.2-20191125.pdf PineTab mainboard Released Schematic ver 1.2] | ||
** [ | ** [https://files.pine64.org/doc/PineTab/PineTab%20Board%20View%20v1.2-20191201-top.pdf PineTab mainboard component placement ver 1.2 - Top View] | ||
** [ | ** [https://files.pine64.org/doc/PineTab/PineTab%20Board%20View%20v1.2-20191201-bottom.pdf PineTab mainboard component placement ver 1.2 - Bottom View] | ||
* PineTab keyboard schematic: | * PineTab keyboard schematic: | ||
** PineTab keyboard and Pinebook (Pro) keyboard using same controller and from same engineering source | ** PineTab keyboard and Pinebook (Pro) keyboard using same controller and from same engineering source | ||
** [ | ** [https://files.pine64.org/doc/PineTab/Pinetab%20HB092A%20Keyboard%20Schematic.pdf PineTab Keyboard Schematic] | ||
** [ | ** [https://files.pine64.org/doc/PineTab/HB092_0884232458_Hynitron_PTP_20200514_662905_Linux_US_BackLight_CRC_175057F5.hex PineTab keyboard firmware code] | ||
** [ | ** [https://files.pine64.org/doc/PineTab/SH68F83V2.0.pdf PineTab Keyboard Controller Datasheet] | ||
* PineTab certifications: | * PineTab certifications: | ||
** [ | ** [https://files.pine64.org/doc/cert/PineTab%20FCC-SDOC%20Certificate-S20060600404001.pdf PineTab FCC Certificate] | ||
** [ | ** [https://files.pine64.org/doc/cert/PineTab%20CE-RED%20Certificate-S20060600403.pdf PineTab CE RED Certificate] | ||
** [ | ** [https://files.pine64.org/doc/cert/PINETAB%20ROHS%20TEST%20REPORT.pdf PineTab ROHS Test Report] | ||
== Datasheets for components and peripherals == | == Datasheets for components and peripherals == | ||
* Allwinner A64 SoC information: | * Allwinner A64 SoC information: | ||
** [ | ** [https://files.pine64.org/doc/datasheet/pine64/A64%20brief%20v1.0%2020150323.pdf Allwinner A64 SoC brief introduction] | ||
** [ | ** [https://files.pine64.org/doc/datasheet/pine64/A64_Datasheet_V1.1.pdf Allwinner A64 SoC Data Sheet V1.1 (Official Released Version)] | ||
** [ | ** [https://files.pine64.org/doc/datasheet/pine64/Allwinner_A64_User_Manual_V1.0.pdf Allwinner A64 SoC User Manual V1.0 (Official Release Version)] | ||
* X-Powers AXP803 PMU (Power Management Unit) information: | * X-Powers AXP803 PMU (Power Management Unit) information: | ||
** [ | ** [https://files.pine64.org/doc/datasheet/pine64/AXP803_Datasheet_V1.0.pdf AXP803 PMIC datasheet] | ||
* LPDDR3 (178 Balls) SDRAM: | * LPDDR3 (178 Balls) SDRAM: | ||
** [ | ** [https://files.pine64.org/doc/datasheet/pinephone/ATL3A1632H12A_mobile_lpddr3_11x11.5_v1.0_1600.pdf Artmem LPDDR3 datasheet] | ||
* eMMC information: | * eMMC information: | ||
** [ | ** [https://files.pine64.org/doc/rock64/PINE64_eMMC_Module_20170719.pdf PINE64 eMMC module schematic] | ||
** [ | ** [https://files.pine64.org/doc/rock64/usb%20emmc%20module%20adapter%20v2.pdf PINE64 USB adapter for eMMC module V2 schematic] | ||
** [ | ** [https://files.pine64.org/doc/rock64/USB%20adapter%20for%20eMMC%20module%20PCB.tar PINE64 USB adapter for eMMC module PCB in JPEG] | ||
** [ | ** [https://files.pine64.org/doc/datasheet/pine64/SDINADF4-16-128GB-H%20data%20sheet%20v1.13.pdf 64GB SanDisk eMMC Datasheet] | ||
* CMOS camera module information: | * CMOS camera module information: | ||
** [ | ** [https://files.pine64.org/doc/datasheet/pinephone/OV5640_datasheet.pdf OV5640 5MP CMOS Image Sensor SoC for Rear Module datasheet] | ||
** [ | ** [https://files.pine64.org/doc/datasheet/pinephone/GC2145%20CSP%20DataSheet%20release%20V1.0_20131201.pdf GC2145 2MP CMOS Image Sensor SoC for Front Module datasheet] | ||
* LCD touch screen panel information: | * LCD touch screen panel information: | ||
** [ | ** [https://files.pine64.org/doc/datasheet/pinetab/GT9271.pdf GOODiX GT9271 Capacitive Touch Controller datasheet] | ||
** [ | ** [https://files.pine64.org/doc/datasheet/pinetab/GT9271_Config_20200818_142030_V66.cfg PineTab GT9271 Capacitive Touch Controller configuration file] | ||
* Lithium battery information: | * Lithium battery information: | ||
Line 86: | Line 86: | ||
* WiFi/BT module information: | * WiFi/BT module information: | ||
** [ | ** [https://files.pine64.org/doc/datasheet/pine64/RTL8723BS.pdf RTL8723BS/RTL8723CS specification] | ||
