Difference between revisions of "PineTab"
88 bytes added ,  18:49, 20 October 2020
Add note about disabling sleep.
m (→‎postmarketOS: version -> versions)
(Add note about disabling sleep.)
Line 140: Line 140:
* First, make sure you have enough free disk space and empty Downloads directory on the PineTab (while not strictly necessary, empty Downloads dir will simplify your typing. You can just move all files from there to another directory).
* go to the Mobian link above and download compressed image (the one ending with .img.gz) - usual recommendation is to download latest, i.e. lowest one.
* Turn off Sleep when idle in the settings. Settings > Battery > Sleep when idle: Never
* Go to the Mobian link above and download compressed image (the one ending with .img.gz) - usual recommendation is to download latest, i.e. lowest one.
* Open terminal and type this in it:
   cd Downloads
   cd Downloads
Line 150: Line 151:
* Now, let's have a look at disks. Type this into terminal:
   lsblk
   lsblk
* It should show you a tree of disks and their partitions. If you don't have microCD card inserted yet, all of them begin with mmcblk2. Also, some of them have something in the "MOUNTPOINT" column
* It should show you a tree of disks and their partitions. If you don't have microSD card inserted yet, all of them begin with mmcblk2. Also, some of them have something in the "MOUNTPOINT" column
* Insert microSD card into PineTab. Note that all information on it will be deleted, so don't insert one with valuable information on it!
* type `lsblk` into terminal again.
19
edits
Navigation menu
