Difference between revisions of "PinePhone Software Releases"
m
m (Change the manjaro lomiri version from Alpha0 to Alpha1)
Line 101: Line 101:
* ''' What works, what does not work '''
NB The first run always stalls before the tutorial. Reboot and it starts from setting the security pin.
The homescreen may be locked unless you boot with a sim card inserted.
May 4th 2020: The SFOS image is now the latest 3.3.0.16 release. This release of SF has Nextcloud integration.
Sept 17. Calls work.....sort of. Volunteer troubleshooters required. 4G works. MTP on the blink. Nextcloud sync works. Camera still WIP.
Sept 17. Calls work.....sort of. Volunteer troubleshooters required. 4G works. Nextcloud sync works. Camera still WIP.
If you're not familiar with SFOS pay attention to the tutorial - the interface works great but isn't immediately obvious. If you are familiar with SF you can skip the tutorial by touching all 4 corners starting top left. There is a limited selection of apps available from the Jolla store, the vast majority are hosted on openrepos.net. The Storeman app for openrepos is now preinstalled, and also Webcat browser as the built in browser is not working at the moment.
Navigation menu
