Difference between revisions of "PineTime devkit wiring"
m
no edit summary
m
m
Line 23: Line 23:
== Pogo Pins connection ==
PineTime Pogo Pins are spring-loaded pins with diamond-shaped tips...
[https://store.pine64.org/product/pinetime-pogopin-jig PineTime Pogo Pins] are spring-loaded pins with diamond-shaped tips...
[[File:PineTime_pogo_tip.jpg|400px]]
Line 38: Line 38:
# With the Battery at left and Sticky Tape pointing right, the SWD Pins will be arranged left to right as: SWDIO, SWDCLK, 3.3V, GND
# Connect the other end of the Pogo Pins to the Jumper Cable that's bundled with PineTime. Connect the Jumper Cable to ST-Link v2 or JLink: SWDIO, SWDCLK, 3.3V, GND. See [[Reprogramming the PineTime|Reprogramming the PineTime (development kit)]]
# With the Sticky Tape pointing right, tap and hold the Pogo Pins firmly on PineTime's SWD Port... But not too hard because the PCB or screen may break. Stabilise the Pogo Pins with your pinky finger as shown above.
# With the Sticky Tape pointing right (away from the Battery), tap and hold the Pogo Pins firmly on PineTime's SWD Port... But not too hard because the PCB or screen may break. Stabilise the Pogo Pins with your pinky finger as shown above.
# PineTime should light up and reboot when the Pogo Pins are connected. You may flash and debug PineTime now. See [[Reprogramming the PineTime|Reprogramming the PineTime (development kit)]]
135
edits
Navigation menu
