Difference between revisions of "PineTime devkit wiring"
m
no edit summary
m
m
Line 37: Line 37:
1. To orientate the pins, stick a piece of Sticky Tape to the Pogo Pins as shown above. The Sticky Tape should point away from PineTime's Battery. Orientation is important... You may damage PineTime with the incorrect orientation!
2. With the Battery at left and Stick Tape pointing right, the SWD Pins will be arranged left to right as: SWDIO, SWDCLK, 3.3V, GND
2. With the Battery at left and Sticky Tape pointing right, the SWD Pins will be arranged left to right as: SWDIO, SWDCLK, 3.3V, GND
3. Connect the other end of the Pogo Pins to the Jumper Cable that's bundled with PineTime. Connect the Jumper Cable to ST-Link v2 or JLink: SWDIO, SWDCLK, 3.3V, GND
135
edits
Navigation menu
