Difference between revisions of "PineTab"
203 bytes added ,  18:05, 15 September 2020
Line 151: Line 151:
Press power button for 7-8s. It makes a sound and you know it's totally off. 3 seconds after, power button  again for 2-3s and it will start to boot. - thanks
@Aperricio on IRC for this hint
=== Display rotated 90° on Arch ARM ===
With the following command you can turn the display to landscape:
* echo 1 | sudo tee /sys/class/graphics/fbcon/rotate
This command does not persist a reboot.
Navigation menu
