Difference between revisions of "PineTab"
251 bytes added ,  19:33, 12 September 2020
Add reset instructions
(Add reset instructions)
Line 139: Line 139:
   sudo reboot
   sudo reboot
* PineTab should boot from the microSD you've just flashed
== Tips and tricks ==
=== Reset ===
If your PineTab is in unknown state or doesn't want to start.
Press power button for 7-8s. It makes a sound and you know it's totally off. 3 seconds after, power button  again for 2-3s and it will start to boot.
15
edits
Navigation menu
