Difference between revisions of "PinePhone APN Settings"
m (redundant)
Line 161: Line 161:
= Carriers That Do Not Work =
* FreedomPop (USA): VoIP-service. Customer service said they require Android 4.3+, and their free calling and texting works only with the Google Play app they make you use. So calls and texts don't work with non-smart phones and won't work with the PinePhone (even though it is a smart phone) because of software incompatibility. However, the data part still work if APN has been seen correctly set to fp.com.attz. You get 200MB free data per month. However, please watch out that you will get ding by $20 top up charge when over 200MB limit.
== FreedomPop (USA) ==
VoIP-service. Customer service said they require Android 4.3+, and their free calling and texting works only with the Google Play app they make you use. So calls and texts don't work with non-smart phones and won't work with the PinePhone (even though it is a smart phone) because of software incompatibility. However, the data part still work if APN has been seen correctly set to '''fp.com.attz'''. You get 200MB free data per month. However, please watch out that you will get ding by $20 top up charge when over 200MB limit.
* VoLTE services like Sprint or Verizon
APN: <code>fp.com.attz</code>
== Sprint ==
VoLTE service. Recently some distributions got VoLTE working using AT commands (see for example the [https://wiki.postmarketos.org/wiki/PINE64_PinePhone_(pine64-pinephone)#VoLTE postmarketOS wiki]), please update this paragraph when having tested Sprint successfully.
APN: <code>cinet.spcs</code>
== Verizon ==
VoLTE service.
== Other ==
Other VoLTE services.
== External links ==
* See also https://forum.pine64.org/showthread.php?tid=9150
Moderator
1,493
edits
Navigation menu
