20
edits
AntonMadness (talk | contribs) m |
AntonMadness (talk | contribs) (manjaro-arm-installer now does run on the PBP.) |
Line 95: | Line 95: | ||
=== Manjaro ARM installer === | === Manjaro ARM installer === | ||
The [https://gitlab.manjaro.org/manjaro-arm/applications/manjaro-arm-installer manjaro-arm-installer] script is intended to install Manjaro ARM directly to SD/eMMC cards without the need for images (including LXQT, Mate & CuboCore editions, as well as full disk encryption) | The [https://gitlab.manjaro.org/manjaro-arm/applications/manjaro-arm-installer manjaro-arm-installer] script is intended to install Manjaro ARM directly to SD/eMMC cards without the need for images (including LXQT, Mate & CuboCore editions, as well as full disk encryption). Running on a Linux x86 computer, it can install Manjaro ARM directly to an empty eMMC using an eMMC to USB adapter. The script can also be run from SD to install an image to the eMMC. | ||
==Kali Linux== | ==Kali Linux== |
edits
