Difference between revisions of "Overclocking"
471 bytes added ,  06:45, 5 June 2020
Add information about preexisting Pinebook Pro override
(Add information about preexisting Pinebook Pro override)
Line 70: Line 70:
More optimised voltages and clocks can be found in <code>arch/arm64/boot/dts/rockchip/rk3399-op1-opp.dtsi</code>
These include a slight overclock and undervolt, they are intended for the OP1 CPU found in many chromebooks but have worked fine in all recorded cases on regular RK3399s in other devices.
Specific to the Pinebook Pro DTS in some kernels is an extra clock speed entry for the big cores in <code>arch/arm64/boot/dts/rockchip/rk3399-pinebook-pro.dts</code>
It overrides the <code>opp08</code> entry for the big core cluster with one that runs 2GHz at 1.3V, it is up to you how to deal with this, either by just skipping opp08 in the main dtsi to keep using that entry or by removing that entry from the Pinebook Pro dts and adding your own to the regular dtsi.
==GPU==
==GPU==
Navigation menu
