Difference between revisions of "PinePhone Software Releases"
user-id -> username
m (→‎postmarketOS: declutter)
(user-id -> username)
Line 41: Line 41:
[https://gitlab.com/ubports/community-ports/pinephone#how-do-i-install-ubuntu-touch-on-my-pinephone UBports PinePhone project]
* ''' user-id/password '''
* ''' username/password '''
Set up during boot
Set up during boot
Line 63: Line 63:
See the [https://gitlab.com/mobian1/wiki/-/wikis/Install project page] for specific installation instructions.
mobian/1234
mobian/1234
Line 123: Line 123:
# Execute it: <code>./flash-it.sh</code>
# Follow the instructions. Some commands in the script require root permissions (for example: mounting and flashing the SD card).
Set PIN on initialization.
Line 152: Line 152:
If you want to report a bug or look at what goes into the PinePhone build of PureOS, visit the Git [http://pureos.ironrobin.net/git/clover/pinephone/ repository.]
purism/123456
purism/123456
Line 168: Line 168:
[https://github.com/nikhiljha/pp-fedora-sdsetup/releases/ flashable images] or [https://github.com/nikhiljha/pp-fedora-sdsetup/tree/image build scripts]
pine/1111
pine/1111
Line 185: Line 185:
https://github.com/dreemurrs-embedded/Pine64-Arch/releases
alarm/alarm
alarm/alarm
Line 204: Line 204:
[https://forum.manjaro.org/t/manjaro-arm-alpha5-for-pinephone-testing-branch/136614 See Manjaro forum announcement of Alpha5 version]
** manjaro/1234
** manjaro/1234
** root/root
** root/root
Line 228: Line 228:
[http://maedevu.maemo.org/images/pinephone/ Maemo Leste test builds.] There is also an [https://github.com/maemo-leste/image-builder image builder], see their wiki for instructions on how to [https://leste.maemo.org/Image_Builder build a custom image].
root/toor
root/toor
Line 265: Line 265:
If necessary, reboot.
* ''' What works, what does not work '''
Line 281: Line 281:
[https://images.plasma-mobile.org/pinephone/ Plasma mobile images can be found here.]
phablet/1234
phablet/1234
Line 318: Line 318:
Tofe recommends using bmaptool ; for example "bmaptool copy http://build.webos-ports.org/luneos-testing/images/pinephone/luneos-dev-image-pinephone-testing-0-15.rootfs.wic.gz /dev/mmcblk0". Rename .wic file to .img for standard dd usage.
Moderator
1,479
edits
Navigation menu
