Moderator
1,479
edits
(→Mobian: Declutter) |
(→SailfishOS: declutter) |
Line 134: | Line 134: | ||
# Execute it: <code>./flash-it.sh</code> | # Execute it: <code>./flash-it.sh</code> | ||
# Follow the instructions. Some commands in the script require root permissions (for example: mounting and flashing the SD card). | # Follow the instructions. Some commands in the script require root permissions (for example: mounting and flashing the SD card). | ||
* ''' user-id/password ''' Set PIN on initialization. | * ''' user-id/password ''' | ||
Set PIN on initialization. | |||
* ''' What works, what does not work ''' | * ''' What works, what does not work ''' | ||
Line 143: | Line 145: | ||
If you're not familiar with SFOS pay attention to the tutorial - the interface works great but isn't immediately obvious. If you are familiar with SF you can skip the tutorial by touching all 4 corners starting top left. There is a poor selection of apps available from the Jolla store, the vast majority are hosted on openrepos.net. The Storeman app for openrepos is now preinstalled, and also Webcat browser as the built in browser is not working at the moment. | If you're not familiar with SFOS pay attention to the tutorial - the interface works great but isn't immediately obvious. If you are familiar with SF you can skip the tutorial by touching all 4 corners starting top left. There is a poor selection of apps available from the Jolla store, the vast majority are hosted on openrepos.net. The Storeman app for openrepos is now preinstalled, and also Webcat browser as the built in browser is not working at the moment. | ||
* ''' How to contribute and report defects ''' | |||
See the [https://sailfishos.org/wiki/Collaborative_Development#Reporting_issues SailfishOS wiki] for links to their forum as well as info required when reporting an issue. See the [https://sailfishos.org/wiki/SailfishOS SailfishOS wiki] for options to contribute | |||
* | * ''' Notes ''' | ||
OTA is supported: <code>zypper refresh && zypper update</code> as root (<code>devel-su</code> to get root access). Things that need reflash are bootloader specific at the moment. If improvements like crust or changes of partition layout are added then you need to reflash. | |||
== PureOS == | == PureOS == |
