Moderator
1,479
edits
(Declutter) |
(→Mobian: Declutter) |
Line 60: | Line 60: | ||
== Mobian == | == Mobian == | ||
[[File:Debian-logo.png]] | [[File:Debian-logo.png]] | ||
An unofficial Debian build for ARM64 running with the Phosh user interface (developed by Purism, Phosh uses Wayland instead of Xorg). The base system is pure Debian, with only the GUI applications and a few others (ModemManager, WiFi chip firmware) being built from modified sources (as well as the kernel and u-boot). Current version is Debian Bullseye. | An unofficial Debian build for ARM64 running with the Phosh user interface (developed by Purism, Phosh uses Wayland instead of Xorg). The base system is pure Debian, with only the GUI applications and a few others (ModemManager, WiFi chip firmware) being built from modified sources (as well as the kernel and u-boot). Current version is Debian Bullseye. | ||
Line 118: | Line 116: | ||
Continue the rest of the instructions on [https://puri.sm/posts/easy-librem-5-app-development-scale-the-screen/ this page]. When you finish, you will have a touch-capable app you can use to adjust resolution any time, useful when switching between various apps. Unlike other solutions, this works across reboots. | Continue the rest of the instructions on [https://puri.sm/posts/easy-librem-5-app-development-scale-the-screen/ this page]. When you finish, you will have a touch-capable app you can use to adjust resolution any time, useful when switching between various apps. Unlike other solutions, this works across reboots. | ||
== SailfishOS == | == SailfishOS == |
