242
edits
Line 108: | Line 108: | ||
Note that this also installs openssh-server, see [https://forum.pine64.org/showthread.php?tid=9016&pid=64038&highlight=%22pinephone-devtools%22#pid64038 here]. | Note that this also installs openssh-server, see [https://forum.pine64.org/showthread.php?tid=9016&pid=64038&highlight=%22pinephone-devtools%22#pid64038 here]. | ||
If you want to share your mobile data internet connection via the USB port then in addition to the above, you should | If you want to share your PinePhone mobile data internet connection via the USB port then in addition to the above, you should | ||
sudo nmcli connection modify USB-gadget ipv4.method shared | sudo nmcli connection modify USB-gadget ipv4.method shared | ||
edits
