Difference between revisions of "PinePhone Software Releases"
Undo revision 5649 by Fxc (talk)
(Testing of new formatting)
(Undo revision 5649 by Fxc (talk))
Line 13: Line 13:
postmarketOS is a preconfigured version of [https://www.alpinelinux.org/ Alpine Linux] for mobile devices that offers a choice of several desktop environments including Plasma Mobile and Phosh.
=== Download location ===
* ''' Download location '''
Rather than downloading a demo image, postmarketOS [https://wiki.postmarketos.org/wiki/Installation_guide recommends the use of their script], pmbootstrap, that can tailor build your SD card for you.
Line 20: Line 20:
[http://images.postmarketos.org/pinephone/ Demo images can be found here.]
=== user-id/password ===
* ''' user-id/password '''
demo/147147 (for demo images only - when building an image with pmbootstrap you set your own user-id and password.
{{Hint|The Phosh lock screen requires your password, but only presents a numeric keyboard. So you should use only numbers in your password.}}
=== What works, what does not work ===
* ''' What works, what does not work '''
See [https://wiki.postmarketos.org/wiki/PINE64_PinePhone_(pine64-pinephone) postmarketOS dedicated PinePhone wiki page]
If you install Firefox browser (or are using a demo image that already has it installed) then [https://wiki.postmarketos.org/wiki/Firefox these hints] in the pmOS wiki are recommended.
=== How to contribute and report defects ===
* ''' How to contribute and report defects '''
[https://gitlab.com/postmarketOS/postmarketos/issues/3 postmarketOS issue tracker for PinePhone support]
=== Contributions ===
* ''' Contributions '''
[https://wiki.postmarketos.org/wiki/Contributing See postmarketOS wiki for options to contribute.]
Line 44: Line 44:
[https://ubuntu-touch.io/ Ubuntu touch] is a mobile version of Ubuntu developed by the UBports community. Installation instructions can be found on [https://gitlab.com/ubports/community-ports/pinephone#how-do-i-install-ubuntu-touch-on-my-pinephone the UBports PinePhone project]. There is also a [https://github.com/goddard/pinephone/ script] to download the latest image and flash to your PinePhone. In the future, Ubuntu Touch will be able to be installed onto the PinePhone with the [https://ubuntu-touch.io/get-ut UBports installer] GUI tool.
[https://gitlab.com/ubports/community-ports/pinephone#how-do-i-install-ubuntu-touch-on-my-pinephone UBports PinePhone project]
Set up during boot
Set up during boot
[https://gitlab.com/ubports/community-ports/pinephone Scroll down to the bottom of this page.]
[https://gitlab.com/ubports/community-ports/pinephone See UBports gitlab page.]
[https://ubports.com/foundation/sponsors See UBports website for how to donate.]
Line 66: Line 66:
An unofficial Debian build for ARM64 running with the [https://developer.puri.sm/Librem5/Software_Reference/Environments/Phosh.html Phosh user interface] (developed by Purism, Phosh uses [https://en.wikipedia.org/wiki/Wayland_(display_server_protocol) Wayland] instead of [https://en.wikipedia.org/wiki/X.Org_Server Xorg]). The base system is pure Debian, with only the GUI applications and a few others (ModemManager, Wifi chip firmware) being built from modified sources (as well as the kernel and u-boot, of course). Current version is Debian Bullseye.
[http://images.mobian-project.org/ Mobian downloadable images]
Line 74: Line 74:
See the [https://gitlab.com/mobian1/wiki/-/wikis/Install project page] for specific installation instructions.
mobian/1234
mobian/1234
See [https://gitlab.com/a-wai/debos-pinephone/-/blob/master/README.md the project's README file] for most up to date status.
Line 83: Line 83:
Check [https://gitlab.com/a-wai/debos-pinephone/-/issues bug tracker] for known issues. Questions? Ask on our [https://forum.pine64.org/showthread.php?tid=9016 thread].
It is recommended that you log your bug reports in [https://gitlab.com/mobian1/issues the project's issue tracker.] As a general rule, issues with third-party apps (even the default ones) should be reported upstream. A Mobian issue would be related to getting the hardware to work on the PinePhone, but if unsure where the issue should be reported just open a ticket or ask.
Feel free to pick an open issue to work on, or send a merge request on [https://gitlab.com/mobian1 Gitlab.]
Line 129: Line 129:
Sailfish OS is a Linux-based operating system based on open source projects such as Mer and including a closed source UI.
The SailfishOS image is built on Gitlab CI. The latest image can be installed using the [https://raw.githubusercontent.com/sailfish-on-dontbeevil/flash-it/master/flash-it.sh flashing script].
The script downloads the image and bootloader from our CI, extracts everything and burns it onto the SD card. ===Note:=== The script will format and erase the SD card!
The script downloads the image and bootloader from our CI, extracts everything and burns it onto the SD card. '''Note:''' The script will format and erase the SD card!
Instructions:
Instructions:
Line 141: Line 141:
# Execute it: <code>./flash-it.sh</code>
# Follow the instructions. Some commands in the script require root permissions (for example: mounting and flashing the SD card).
=== user-id/password === Set PIN on initialization.
* ''' user-id/password ''' Set PIN on initialization.
May 4th 2020: The SFOS image is now the latest 3.3.0.16 release. This has resolved many problems (for example MTP file transfer now works) but there are several glitches, the most serious being total freeze requiring reboot. Random hissing noise for about 10 seconds. This release of SF has Nextcloud integration.
Line 164: Line 164:
PureOS is a GNU/Linux distribution focusing on privacy and security, using the GNOME desktop environment. It is developed and maintained by Purism.
This is an unofficial/unsupported PinePhone port by ''mozzwald'' and maintained by clover that can be downloaded [http://pureos.ironrobin.net/droppy/#/Images here.]
=== source code ===
* ''' source code '''
If you want to report a bug or look at what goes into the PinePhone build of PureOS, visit the Git [http://pureos.ironrobin.net/git/clover/pinephone/ repository.]
purism/123456
purism/123456
=== Build instructions ===
* ''' Build instructions '''
If you want to build it yourself you can follow the instructions posted [https://mozzwald.com/pp/pureos-pinephone-build-instructions.txt here].
Line 183: Line 183:
See [https://forum.pine64.org/showthread.php?tid=9347 this thread in the forum.]
[https://github.com/nikhiljha/pp-fedora-sdsetup/releases/ flashable images] or [https://github.com/nikhiljha/pp-fedora-sdsetup/tree/image build scripts]
The images are compressed with zstd because the maintainer needs an excuse to use zstd.
pine/1111
pine/1111
* WiFi, Bluetooth, SMS, Data, Calls all work!
* There are still a few bugs though, and [some features don't have driver support yet https://xnux.eu/devices/pine64-pinephone.html#toc-feature-driver-support-matrix] on any PinePhone distribution.
Please send your bug reports at [https://github.com/nikhiljha/pp-fedora-sdsetup/issues the project's issue tracker.] Be sure to include logs if applicable!
Please help! Send us merge requests on [https://github.com/nikhiljha/pp-fedora-sdsetup/ Github.]
Line 206: Line 206:
An (unofficial) barebone Arch Linux ARM image, all you have is just a shell and SSH.
https://github.com/dreemurrs-embedded/Pine64-Arch/releases
alarm/alarm
alarm/alarm
It's just fast and smooth, there's nothing, you'll have to install a desktop at your own. GNOME is a good example to look at.
To access the device, ssh to 172.16.42.1 with the credentials above.
Feel free to send us merge requests on [https://github.com/dreemurrs-embedded/Pine64-Arch/pulls GitHub.]
Line 224: Line 224:
[https://forum.manjaro.org/t/manjaro-arm-alpha5-for-pinephone-testing-branch/136614 See Manjaro forum announcement of Alpha5 version]
** manjaro/1234
** manjaro/1234
** root/root
** root/root
[https://forum.manjaro.org/t/manjaro-arm-alpha5-for-pinephone-testing-branch/136614 See Manjaro announcement.]
In particular phone calls do NOT yet work from the Phone application.
[https://forum.manjaro.org/t/manjaro-arm-alpha5-for-pinephone-testing-branch/136614 See the end of the announcement here.]
Line 250: Line 250:
More detailed information can be found on [https://leste.maemo.org/Main_Page the Maemo Leste wiki], or follow [https://maemo-leste.github.io/ announcements on their website], and check out [https://leste.maemo.org/Leste_FAQ Frequently Asked Questions].
[http://maedevu.maemo.org/images/pinephone/ Maemo Leste test builds.] There is also an [https://github.com/maemo-leste/image-builder image builder], see their wiki for instructions on how to [https://leste.maemo.org/Image_Builder build a custom image].
root/toor
root/toor
You may use "sudo" directly.
For current status and work arounds please read their [https://leste.maemo.org/PinePhone PinePhone wiki page], and update as necessary (make sure to notify them of new issues by leaving a report on their github, see below).
=== Where to Report Issues ===
* ''' Where to Report Issues '''
Most discussion occurs at #maemo-leste on freenode IRC. The Maemo website also has an [https://talk.maemo.org/showthread.php?p=1565822 ongoing forum thread] for feedback about Maemo Leste on the PinePhone BraveHeart edition.
All other contact information is listed on the [https://leste.maemo.org/Main_Page main page] of the Maemo wiki. You should [https://github.com/maemo-leste/bugtracker/issues submit bug reports] on github. To track known issues, you may use these search terms: [https://github.com/maemo-leste/bugtracker/issues?utf8=%E2%9C%93&q=is%3Aissue+is%3Aopen+pinephone pinephone], [https://github.com/maemo-leste/bugtracker/issues?utf8=%E2%9C%93&q=is%3Aissue+is%3Aopen+pine64 pine64]
=== Development ===
* ''' Development '''
Learn about [https://leste.maemo.org/Development development], [https://leste.maemo.org/Development/Porting_Packages porting packages], [https://leste.maemo.org/Development/Building_Packages building packages], [https://leste.maemo.org/Development/Tasks todo list], and general info on [https://wiki.debian.org/HowToPackageForDebian how to package for Debian]. Some tasks have funding available.
Line 275: Line 275:
You can install Nemo on any device that runs Sailfish, see the above website for details. Or you can flash the image to SD card on the PinePhone, download here https://yadi.sk/d/8oSZp-frGidscw (requires Yandex Disk account).
[https://github.com/neochapay/nemo-device-dont_be_evil/ Download location is here on GitHub.] The latest version here is not  an .img and not for beginners!
[https://github.com/neochapay/nemo-device-dont_be_evil/ Scroll down the page here.]
For more info please visit [https://github.com/neochapay/nemo-device-dont_be_evil neochapay's github page]
== KDE Neon ==
== KDE Neon ==
Line 292: Line 292:
Based on KDE Neon for the desktop, comes with Plasma Mobile.
[https://images.plasma-mobile.org/pinephone/ Plasma mobile images can be found here.]
phablet/1234
phablet/1234
<!--=== What works, what does not work ===
=== Contributions ===-->
== NixOS ==
== NixOS ==
Line 314: Line 314:
There is no pre-built complete image. For now users are expected to follow the instructions in the [https://mobile.nixos.org/getting-started.html Getting Started page], and on [https://mobile.nixos.org/devices/pine64-pinephone-braveheart.html the device's page].
This information may change, but currently it boots, it's as compatible as the Android-based devices are with Mobile NixOS. It even supports a bit more since it can use Wi-Fi.
Line 322: Line 322:
</cite>
</cite>
On [https://github.com/NixOS/mobile-nixos/issues the project's repository]. Please specify that you are using a PinePhone when reporting issues.
[https://nixos.org/nixos/community.html Details about contributions and donations are on the NixOS website.]
Line 332: Line 332:
Based on WebOS by LG, comes with Luna Next desktop environment.
[http://build.webos-ports.org/luneos-testing/images/pinephone/ LuneOS test image for PinePhone]
Tofe recommends using bmaptool ; for example "bmaptool copy http://build.webos-ports.org/luneos-testing/images/pinephone/luneos-dev-image-pinephone-testing-0-15.rootfs.wic.gz /dev/mmcblk0". Rename .wic file to .img for standard dd usage.
<!--=== user-id/password ===
= Factory Test OS =
= Factory Test OS =
Line 357: Line 357:
= Installing other ARM64 distributions =
===Warning:=== Distributions not on this page may not even boot after you follow this section. In the best case, they will be barely usable. This is more for fun, or if you would like to port a new distribution to the PinePhone.
'''Warning:''' Distributions not on this page may not even boot after you follow this section. In the best case, they will be barely usable. This is more for fun, or if you would like to port a new distribution to the PinePhone.
===Note:=== This section uses megi's kernel releases, and not the official ones from PINE64. While it is possible to use the official (and in the future, mainline) kernel, megi provides binary releases, which makes it very easy.
'''Note:''' This section uses megi's kernel releases, and not the official ones from PINE64. While it is possible to use the official (and in the future, mainline) kernel, megi provides binary releases, which makes it very easy.
If you would like to see specific commands for how to complete these steps, see https://github.com/nikhiljha/pp-fedora-sdsetup (an example for Fedora) or https://xnux.eu/howtos/install-arch-linux-arm.html (an example for Arch Linux).
Moderator
1,493
edits
Navigation menu
