Difference between revisions of "PinePhone FAQ"
193 bytes added ,  14:38, 18 May 2020
m (→‎Hardware: added)
(→‎Battery: added)
Line 18: Line 18:
If your battery is stuck inside the PinePhone, grab a screw driver and completely unscrew all the screws of the midframe. Then pull out the battery (you may have to fully take off the midframe in some cases to get it out). And then rescrew the midframe, but only tighten the screws to the point where they are just barely tight to hold. This should allow you to remove the battery easily.
==== The battery is discharging while the phone is powered off (BraveHeart Edition) ====
The cause of this issue is currently investigated. The issue is not present on the Community Edition.
=== Kill Switches ===
Moderator
1,493
edits
Navigation menu
