Difference between revisions of "PinePhone FAQ"
132 bytes added ,  21:05, 17 May 2020
(→‎Battery: format)
Line 8: Line 8:
=== Battery ===
=== Battery ===
If your battery is stuck inside the pinephone, grab a screw driver and completely unscrew all the screws of the midframe. Then pull out the battery (you may have to fully take off the midframe in some cases to get it out)... And then rescrew the midframe, but only tighten the screws to the point where they are just barely tight to hold. This should allow you to remove the battery easily.
==== The battery is stuck inside the phone ====
The battery can be stuck in the phone if the screws of the frame are overtightened.
If your battery is stuck inside the PinePhone, grab a screw driver and completely unscrew all the screws of the midframe. Then pull out the battery (you may have to fully take off the midframe in some cases to get it out). And then rescrew the midframe, but only tighten the screws to the point where they are just barely tight to hold. This should allow you to remove the battery easily.
== Software ==
== Software ==
Moderator
1,493
edits
Navigation menu
