Difference between revisions of "PinePhone Software Releases"
fixes on the factory test OS
(add Factory Test OS)
(fixes on the factory test OS)
Line 367: Line 367:
On the BraveHeart model there was a pmOS based basic factory test OS pre-installed on the eMMC. Martijn Braam from pmOS has improved the functionality of the image considerably.
Since the 20200501 version it is able to test all the hardware and also includes Jumpdrive functionality to install a new OS to the eMMC.
Since the 20200501 version it is able to test all the hardware.  It also includes functionality to install a new OS to the eMMC when using with an test image that includes that OS image. The downloadable image just does the hardware tests.
No need to install to eMMC to test your device, you can just copy it to mSD and test from there. New versions are distributed as part of the pmOS distribution.
Do not flash eMMC to test your device, just copy it to mSD and test from there. New versions are distributed as part of the pmOS distribution.
Links:
Links:
Navigation menu
