Difference between revisions of "PinePhone"
9 bytes added ,  19:20, 15 May 2020
Line 125: Line 125:
== Modem and Carrier Support ==
There is a document about using the modem from January 18th 2020 by user ''megi'' [https://megous.com/dl/tmp/modem.txt here]. The script at the end to disable the modem before power off is pretty essential to avoid corrupting your modem's flash memory.
{{Hint|There is a document about using the modem from January 18th 2020 by user ''megi'' [https://megous.com/dl/tmp/modem.txt here]. The script at the end to disable the modem before power off is pretty essential to avoid corrupting your modem's flash memory.}}
To check if the PinePhone is supported on your carrier:
Moderator
1,493
edits
Navigation menu
