Difference between revisions of "PinePhone Installation Instructions"
Line 15: Line 15:
If you need step-by-step instructions for writing an image to an SD card, check [[NOOB#Step-by-Step_Instructions_to_Flashing_MicroSD_Cards|the NOOB guide]], then return to this page.
=== Bmaptool ===
=== bmaptool ===
Download the .img.xz and the .img.bmap files, then run <code>bmaptool copy --bmap image.bmap image.xz /dev/sdX</code>. This takes 2.5mins to flash a 4Gb file.
=== dd ===
Make sure to select the correct device using <code>lsblk</code>. Then run dd with the correct device:
<code>sudo dd if=pine.img of=/dev/[DEVICE] bs=1M status=progress conv=fsync</code>
== Installation to eMMC (Optional) ==
Moderator
1,493
edits
Navigation menu
