Difference between revisions of "PinePhone"
227 bytes removed ,  15:58, 15 May 2020
Changes to OS section, removed legacy factory image notes
(Changes to OS section, removed legacy factory image notes)
Line 141: Line 141:
=== APN settings ===
For tested APN settings see [[PinePhone APN Settings]].
For tested APN settings and how to apply them see [[PinePhone APN Settings]].
== Factory Test Requirements ==
Most of the self tests should just work, but a couple of them will fail unless certain requirements are met.
=== RTL8723CS - WiFi ===
* The self test needs a visible access point nearby so it can discover an SSID.
* The self test may fail if the battery charge is too low.
=== EG25 - Modem ===
* A working micro-SIM that doesn't require a PIN to unlock
* Enough battery charge
== Operating Systems ==
Line 163: Line 149:
The [[PinePhone Software Releases]] page has a complete list of currently supported phone-optimized Operating System images that work with the PinePhone as well as other related software information. As soon as other general Linux distributions ship with kernel V5.7, they will also be able to run unmodified on the device.
== Flashing eMMC using Jumpdrive ==
=== Installation instructions ===
For instructions how to install the operating systems on the eMMC or SD card see [[PinePhone Installation Instructions]].
=== Flashing eMMC using Jumpdrive ===
[[File:jumpdrive.jpg|400px|thumb|right|Jumpdrive running on the PinePhone]]
Line 172: Line 162:
Latest Jumpdrive can be found [https://github.com/dreemurrs-embedded/Jumpdrive/releases/ here].
=== Detailed Usage Instructions ===
==== Detailed Usage Instructions ====
# Download the Jumpdrive image
Line 184: Line 174:
Jumpdrive also acts as a rescue image in case if you messed up your installation. To do so, you can telnet to '''172.16.42.1''', mount rootfs and fix it!
=== Resize file system ===
==== Resize file system ====
If you flash a 4GB image distribution (such as phosh+debian) to your eMMC, your eMMC will only have a 3.7G partition on it. To use the entire 14.7G on the eMMC, run the following commands:
Line 194: Line 184:
=== Feedback ===
==== Feedback ====
Moderator
1,493
edits
Navigation menu
