Difference between revisions of "PinePhone Software Releases"
update
m (moved inactive project down, actively updated projects up)
(update)
Line 248: Line 248:
* ''' What works, what does not work '''
The current (6 Feb) version of Sailfish has a defect with the auto brightness: on first boot this means you get a blank screen. You need to hold your phone up to a bright light to enable the screen, then disable the auto brightness in Settings, Display. [https://forum.pine64.org/showthread.php?tid=9054 See this forum thread.] If you're not familiar with SFOS, be prepared by having a Jolla account and skip the tutorial by touching all 4 corners starting top left. This is just because holding a light over the sensor can be tricky, otherwise the SFOS tutorial is necessary as the UI is not that intuitive.
The current (2 Apr) version of Sailfish no longer has a defect with the auto brightness! If you're not familiar with SFOS, be prepared by having a (free) Jolla account and pay attention to the tutorial - the interface works great but isn't immediately obvious. If you are familiar with SF you can skip the tutorial by touching all 4 corners starting top left. There is a poor selection of apps available from the Jolla store. To enable openrepos.net install the Storeman app by downloading the rpm from https://openrepos.net/content/osetr/storeman. Browse the apps and add repository first from the pulley menu before installing the app.
* ''' Where/how to report defects '''
Navigation menu
