Difference between revisions of "PinePhone Software Releases"
Line 83: Line 83:
=== Resize from within PinePhone ===
eMMC: The recommended method is to resize the partition on eMMC (flashed with the operating system) by booting another image from the SD card: that way, the eMMC will be unmounted. It is '''not recommended''' to resize eMMC while booted from eMMC! Resizing a currently mounted partition can have weird results.
eMMC: You can use Jumpdrive to access the eMMC directly, and resize the partition after flashing the image. Otherwise, you would need to resize the partition on eMMC (flashed with the operating system) by booting another image from the SD card: that way, the eMMC will be unmounted. It is '''not recommended''' to resize eMMC while booted from eMMC! Resizing a currently mounted partition can have weird results.
SD card: It is generally not possible to boot from eMMC to partition the unmounted SD card, because of the boot order -- you would have to write the image to the empty SD card first, then resize partition, all without rebooting. It is also not recommended to resize the SD card while booted from SD card! Resizing a currently mounted partition can have weird results.
110
edits
Navigation menu
