110
edits
Line 57: | Line 57: | ||
# Open terminal and resize partition to fill up entire disk (see below). | # Open terminal and resize partition to fill up entire disk (see below). | ||
=== | === Risky Method === | ||
Warning: This copies a mounted filesystem, which can lead to instability and data corruption. May cause bugs. Do not use | Warning: This copies a mounted filesystem, which can lead to instability and data corruption. May cause bugs. Do not use long term. | ||
# Prepare a new SD card, flash desired OS to the SD card | # Prepare a new SD card, flash desired OS to the SD card |
edits
