Difference between revisions of "PinePhone Software Releases"
→‎Software Releases: imported text from /PinePhone page + added to debian+phosh description
(→‎Software Releases: imported text from /PinePhone page + added to debian+phosh description)
Line 60: Line 60:
== postmarketOS ==
== postmarketOS ==
http://files.pine64.org/sw/pine64_installer/json/postmarketos.png
postmarketOS is an experimental, touch-optimized and pre-configured Alpine Linux that offers a choice of several desktop environments including Plasma Mobile and phosh.
postmarketOS is a preconfigured version of [https://www.alpinelinux.org/ Alpine Linux] for mobile devices that offers a choice of several desktop environments including Plasma Mobile and phosh. The latest builds can be downloaded from the [https://images.postmarketos.org/pinephone/ images page] to be flashed to the PinePhone.
More information is available at [https://postmarketos.org postmarketos.org] and on their [https://wiki.postmarketos.org/wiki/PINE64_PinePhone_(pine64-pinephone) dedicated PinePhone wiki page].
* ''' Download location '''
Line 88: Line 91:
A short, state-of-the-art (as at 5 Feb 2020) [https://youtu.be/ST_BjKicTAk demo on YouTube.]
[https://ubuntu-touch.io/ Ubuntu touch] is a mobile version of Ubuntu developed by the UBports community. Images can be downloaded from [https://ci.ubports.com/job/rootfs/job/rootfs-pinephone/ here]. In the future, Ubuntu Touch will be able to be installed onto the PinePhone with the [https://ubuntu-touch.io/get-ut UBports installer] GUI tool.
Line 93: Line 98:
* ''' user-id/password '''
The default password is ''phablet''
The default password is <code>phablet</code>
* ''' What works, what does not work '''
Line 156: Line 161:
The SailfishOS image is built on Gitlab CI. The latest image can be installed using the [https://raw.githubusercontent.com/sailfish-on-dontbeevil/flash-it/master/flash-it.sh flashing script].
The script downloads the image and bootloader from our CI, extracts everything and burns it onto the SD card.
The script downloads the image and bootloader from our CI, extracts everything and burns it onto the SD card. '''Note:''' The script will format and erase the SD card!
''Instructions:''
''Instructions:''
# Download the flashing script
# Insert a microSD card in your device
Line 167: Line 171:
# Follow the instructions. Some commands in the script require root permissions (for example: mounting and flashing the SD card).
''Note'': The script will format and flash the SD card, make sure that you don't have any important data on the SD card!
Note that after baking µSD card and booting phone, as per [https://www.reddit.com/r/pinephone/comments/f1l7bm/sailfish_os_on_pinephone_best_os_so_far_in_my/fh8o0s2/ Reddit comment] you have to adjust autobrightness settings in order to actually see interface.
The current (6 Feb) version of Sailfish has a defect with the auto brightness: on first boot this means you get a blank screen. You need to hold your phone up to a bright light to enable the screen, then disable the auto brightness in Settings, Display. [https://forum.pine64.org/showthread.php?tid=9054 See this forum thread.] If you're not familiar with SFOS, be prepared by having a Jolla account and skip the tutorial by touching all 4 corners starting top left. This is just because holding a light over the sensor can be tricky, otherwise the SFOS tutorial is necessary as the UI is not that intuitive.
* ''' Where/how to report defects '''
Line 265: Line 269:
== Debian + Phosh ==
The description says it all - see [https://forum.pine64.org/showthread.php?tid=9016 this thread in the forum.]
Debian for ARM64 running with phosh user interface. See [https://forum.pine64.org/showthread.php?tid=9016 this thread in the forum.]
<div class="center" style="background-color: lightyellow;">[[#top | '''Return to top of page''']]</div>
== Neon ==
[https://images.plasma-mobile.org/pinephone/ Neon images] A changelog (for the postmarketOS version) can be found [https://images.postmarketos.org/pinephone/#changelog here] username: phablet pw: 1234
== Aurora ==
Available soon.
= Other Resources =
= Other Resources =
110
edits
Navigation menu
