Difference between revisions of "Pinebook Pro Debian Installer"
Line 51: Line 51:
| Debian issue https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=948708
| Use the firefix-esr 68.4.1esr-1~deb10u1 from Debian Buster, it works perfect
| Use a different browser meanwhile.
| needs to be pinned, also needs a lib
| You can use the firefox-esr 68.4.1esr-1~deb10u1 from Debian Buster, it works perfect (needs to be pinned, also needs a lib). Other browsers such as Epiphany (also has issues, white screen often, mouse movement re-displays under mouse), Konqueror and Falkon also have issues, don't work (dbind)
| Use a different browser meanwhile (epiphany for instance)
| But epiphany also has issues, white screen often, mouse movement re-displays (under mouse)
| Both Konqueror and Falkon also have issues, don't work (dbind)
| cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
| <pre>cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2</pre>
| Debian issue https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=857054
| If having FDE, it fails to load at boot as the firmware is not included in initramfs
| Include the dptx.bin firmware in the initramfs (https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=857054#5)
| See https://forum.pine64.org/showthread.php?tid=8487&pid=57202#pid57202
| Bluetooth doesn't work; bluetooth hci1: Direct firmware load for brcm/BCM4345C5.hcd failed with error -2
Line 69: Line 68:
| Suspend doesn't work properly, when lid is closed, the laptops gets hot and dramatically dry the battery
24
edits
Navigation menu
