Difference between revisions of "PineTab"
6 bytes added ,  23:03, 4 January 2020
m
General fixes for inconsistent information
(OS)
m (General fixes for inconsistent information)
Line 21: Line 21:
* '''Screen:''' 10.1" IPS 800x1280 Capacitive LCD
* '''Attachments/Accessories:''' Magnetically attached keyboard (optional)
* '''Battery:''' 6000MAh (4.5Ah)
* '''Battery:''' 6000MAh (6Ah)
* '''Misc. features:'''
** Volume rocker and home button
Line 28: Line 28:
== Keyboard ==
== Keyboard ==
'''Overview:''' The PinePad detachable keyboard features a full function row, FN key functionality, meta key (where the Windows key would be) and all of the keys you need for daily use.
'''Overview:''' The PineTab detachable keyboard features a full function row, FN key functionality, meta key (where the Windows key would be) and all of the keys you need for daily use.
'''FN keys:''': Pause/play (F2), Stop (F3), Previous(F4), Next(F5), Music (F6), Mail (F7), Home (F8), Mute (F9), Vol- (F10), Vol+ (F11), Disable touchpad (F12), NumLock (Insert), Scroll Lock (Delete), PgUp (Up Arrow), PgDn (Down Arrow), Home (Left Arrow), End (Right Arrow), Digital Numpad (7,8,9,0,U,I,O,P,J,K,L,;,M,.,/)
== Operating Systems ==
The PinePhone will automatically boot from microSD if a bootable card is inserted. Although it is technically possible to use any ARM distro (because the PinePhone uses the mainline kernel), there are a few that are designed specifically for phones:
The PineTab will automatically boot from microSD if a bootable card is inserted. Although it is technically possible to use any ARM distro (because the PineTab uses the mainline kernel), there are a few that are designed specifically for phones and tablets:
* [[#postmarketOS|postmarketOS]]
* [[#Arch Linux ARM|Arch Linux ARM]]
Navigation menu
