Difference between revisions of "Pinebook Pro"
169 bytes added ,  08:20, 12 December 2019
Added asound.state from Manjaro
m (→‎Datasheets for Components and Peripherals: added text to link: (UPDATED))
(Added asound.state from Manjaro)
Line 285: Line 285:
* If you cannot get sound from the headphone jack, but can get sound from the speakers, then the headphone / UART console switch may be set to the UART mode. You can open the back and check the position of the switch. If set to UART mode, switch it to headphone mode. See the parts layout for the location and correct position of the switch.
* When using the USB C alternate DisplayPort mode, it is possible that the audio has been re-directed through this path. If your monitor has speakers, then see if they work.
* See this [https://gitlab.manjaro.org/manjaro-arm/packages/community/pinebookpro-post-install/blob/master/asound.state /var/lib/alsa/asound.state] for some Alsa tweaks
=== USB docks & USB C alternate mode video ===
24
edits
Navigation menu
