Difference between revisions of "User:Earboxer/Shim U101"
no edit summary
Line 1: Line 1:
[[User:Earboxer/Deframe_PinePhone First, remove the frame]]
Fold a small piece of cardstock three times over.
Fold a small strip of cardstock three times over, leaving a tail
[[File:PinePhone-U101-shim-creation.jpg|300px]]
Slide it in between U101 and the screen, being careful not to lift up the USB-C Side Board.
Slide it in, tail-first between U101 and the screen assembly, being careful not to lift up the USB-C Side Board.
(If you lift up the USB-C Side Board, you might mess up the connection between the PCB and PCF, which may [[PinePhone_Hardware_Issues#Bottom_Speaker break the speaker/rumble]], and will require a soldering iron to fix)
[[File:PinePhone-U101-shim-installed.jpg|400px]]
(If you lift up the USB-C Side Board, you might mess up the connection between the PCB and PCF, which may [[PinePhone_Hardware_Issues#Bottom_Speaker|break the speaker/rumble]], and will require a soldering iron to fix)
[[File:PinePhone-U101-shim-example.jpg|300px]]
Reassemble the PinePhone
25
edits
Navigation menu
