Difference between revisions of "Quartz64 Installing Arch Linux ARM"
Hooray, 5.18 brings with it the required config changes
m (Update the kernel package to a 5.18-rc kernel with PCIe patches)
(Hooray, 5.18 brings with it the required config changes)
Line 1: Line 1:
{{note|This page is a work in progress. If you are not familiar with user-mode QEMU, wait for [https://github.com/archlinuxarm/PKGBUILDs/pull/1918 the necessary kernel config changes] to be made.}}
Commands to be run as a normal user are prefixed with <code>$</code>, commands to be run as root are prefixed with <code>#</code>. We assume your target device is <tt>/dev/sdX</tt>, adjust accordingly.
Line 107: Line 105:
For a different type of Quartz64 device (e.g. Model B) replace the <tt>fdt</tt> line with the appropriate <tt>/boot</tt>-relative path to the device tree.
=== Finishing Touches ===
{{note|Here's where you'd do the part I said was iffy and won't be necessary once my PR is merged. You'll need an Arch Linux or Manjaro system. If it's not an aarch64 system, you'll also need <tt>qemu-user-static</tt>.
First, get [https://fratti.ch/quartz64/alarm-kernels/linux-aarch64-rc-5.18.rc6-1-aarch64.pkg.tar.zst the linux-aarch64-rc package I patched and built], then copy it somewhere into your mounted root.
Alternatively, patch and build the package yourself by [https://github.com/CounterPillow/PKGBUILDs/commit/622e03ba3753f823ea903bdbbf59c2f400dd2334 using my forked package sources].
Next, <code>arch-chroot</code> into the mounted root:
<code># arch-chroot /mnt/alarm-root</code>
and install the package
<code># pacman -U linux-aarch64-rc-5.18.rc6-1-aarch64.pkg.tar.zst</code>
Then <code>exit</code> the chroot again once it's done installing.
Once done, unmount the partitions:
  # umount /mnt/alarm-root/boot
504
edits
Navigation menu
