2
edits
(→Installation to the microSD: removed confusing cross-reference, swapped image to newer version) |
(Add information about new u-boot location on Danctnix (arch)) |
Line 131: | Line 131: | ||
sudo dd if=/dev/zero of=/dev/'''[DEVICE]''' bs=8k seek=1 count=4 | sudo dd if=/dev/zero of=/dev/'''[DEVICE]''' bs=8k seek=1 count=4 | ||
will clear the relevant sectors of your card. | will clear the relevant sectors of your card. | ||
Since Danctnix (arch) switched to a gpt partition table from mbr in May of 2022 it installs u-boot at an offset of 128k instead of 8k, which means this command must be used instead | |||
sudo dd if=/dev/zero of=/dev/'''[DEVICE]''' bs=32k seek=4 count=1 | |||
== Web resources == | == Web resources == |
edits
