Difference between revisions of "PinePhone Pro Software Releases"
→‎Gentoo: Updated section
(→‎Gentoo: Updated section)
Line 32: Line 32:
[[File:GentooLogo.png|right|100px]]
{{hint|Please consider cross-compiling the software on the computer.
There are unofficial Gentoo overlays with ebuilds for the PinePhone Pro. There are no images - the image must be built manually, including picking the kernel, bootloader and the desired desktop environment. The ARM64 version of Gentoo has to be selected. The PinePhone Pro will not boot with P-Boot but will boot with U-Boot, there is an ebuild for it.
Long compilation times and heat production can lead to a reduced lifespan of the phone.}}
There is an unofficial Gentoo overlay with ebuilds for the PinePhone Pro.
There are no images - you'll be building it yourself, picking which kernel, bootloader and desktop environment you want to use.
The PinePhone Pro will not work with P-Boot but will with U-Boot, there is an ebuild for it you can use.
You will be using the arm64 version of Gentoo.
==== Download ====
==== Download ====
Line 47: Line 41:
See https://stealthgun.tweakblogs.net/blog/19830/gentoo-on-a-pinephone-pro for the documentation.
{{Info|Please consider cross-compiling the software on the computer. Long compilation times and heat production can lead to a reduced lifespan of the phone.}}
Moderator
1,493
edits
Navigation menu
