665
edits
m (→Installing The Root File System: fix fstab pass number) |
m (Update the kernel package to a 5.18-rc kernel with PCIe patches) |
Line 112: | Line 112: | ||
{{note|Here's where you'd do the part I said was iffy and won't be necessary once my PR is merged. You'll need an Arch Linux or Manjaro system. If it's not an aarch64 system, you'll also need <tt>qemu-user-static</tt>. | {{note|Here's where you'd do the part I said was iffy and won't be necessary once my PR is merged. You'll need an Arch Linux or Manjaro system. If it's not an aarch64 system, you'll also need <tt>qemu-user-static</tt>. | ||
First, get [https:// | First, get [https://fratti.ch/quartz64/alarm-kernels/linux-aarch64-rc-5.18.rc6-1-aarch64.pkg.tar.zst the linux-aarch64-rc package I patched and built], then copy it somewhere into your mounted root. | ||
Alternatively, patch and build the package yourself by [https://github.com/ | Alternatively, patch and build the package yourself by [https://github.com/CounterPillow/PKGBUILDs/commit/622e03ba3753f823ea903bdbbf59c2f400dd2334 using my forked package sources]. | ||
Next, <code>arch-chroot</code> into the mounted root: | Next, <code>arch-chroot</code> into the mounted root: | ||
Line 122: | Line 122: | ||
and install the package | and install the package | ||
<code># pacman -U linux-aarch64-5. | <code># pacman -U linux-aarch64-rc-5.18.rc6-1-aarch64.pkg.tar.zst</code> | ||
Then <code>exit</code> the chroot again once it's done installing. | Then <code>exit</code> the chroot again once it's done installing. |
edits
