Difference between revisions of "ROCKPro64"
Line 887: Line 887:
* To allow enough clearance between the board and the bracket you either need to print four copies of the washer model or add nut(s) between the board and the bracket
* If using nuts for the clearance between the board and the brackets, make sure it creates at least 3.2mm of spacing in between
* Depending on the accuracy and calibration of a 3D printer, slight deviation can occur and you likely need to manually widen some of the holes to allow screws to fit
= Other Resources =
= Other Resources =
6
edits
Navigation menu
