Moderator
1,491
edits
(→Manjaro ARM: added Phosh link) |
(→Mobian: notes) |
Line 103: | Line 103: | ||
[https://images.mobian.org/pinephonepro/ Images] | [https://images.mobian.org/pinephonepro/ Images] | ||
{{Info|Tow-Boot required to be able to boot the images, see [https://wiki.mobian-project.org/doku.php?id=install-linux here]!}} | |||
{| class="wikitable" | {| class="wikitable" | ||
Line 112: | Line 114: | ||
==== Notes ==== | ==== Notes ==== | ||
The development is work in progress. See [https://gitlab.com/mobian1/devices/pinephonepro-support pinephonepro-support] for further information. | The development is work in progress. See [https://gitlab.com/mobian1/devices/pinephonepro-support pinephonepro-support] for further information. The Mobian wiki can be found [https://wiki.mobian-project.org/ here]. | ||
In order to connect to the device using SSH/SCP via WiFi, you need to install SSH on the device. You can do this by executing the following in a shell: "sudo apt-get install ssh", afterwards you can connect via SSH/SCP via WiFi using the PinePhonePro's IP address on port 22. | In order to connect to the device using SSH/SCP via WiFi, you need to install SSH on the device. You can do this by executing the following in a shell: "sudo apt-get install ssh", afterwards you can connect via SSH/SCP via WiFi using the PinePhonePro's IP address on port 22. |
